Belling
Belling Spare Parts
Spares for Belling ovens, cookers, dishwashers, cooker hoods and tumble dryer parts. Belling is part of the Glen Dimplex Group which includes Stoves and New World as they are common to all the group's products.
If you are unsure or can't find the Belling spare part that you are looking for please contact us and we will be only too happy to help you locate a part you need.
You can get technical support using our oven and cooker forum where oven and oven repair engineers will help you if they can. There is also more help on repair your cooker or oven in the oven and cooker self help section.
Popular Belling Parts
Washing Machine Drive Belt - 1236J6
Genuine washing machine drive belt used on Vestel produced machines as shown or others as appropriate or advised More InformationIn stockIn stock£13.49 -
Dishwasher Drain Pump
This Hanyu B30-6A drain pump is used on the dishwasher models as shown but can also be found used on may other makes and models as advised More InformationIn stockIn stock£39.49 -
Cooker Wire Shelf - Main Oven - 460mm x 310mm
Genuine replacement part. Suitable for a range of Belling, Stoves and New World Cooker and Ovens. More InformationIn stockIn stock£36.99 -
Cooker Fan Motor
Genuine replacement part. Suitable for a range of Belling, Stoves and New World Cooker and Ovens. More InformationIn stockIn stock£57.49 -
Cooker Timer Assembly - Green Display
Genuine replacement electronic oven clock or timer unit to fit models as shown only unless advised accordingly, green display More InformationOut of stockOut of stock£84.99 -
Cooker Selector Switch
Oven selector switch used on the models as shown or as advised to control the various functions of the oven More InformationIn stockIn stock£31.49 -
Washing Machine Door Handle
Quality compatible spare part for a wide range of Washing Machines. More InformationIn stockIn stock£6.75 -
Washing Machine Door Handle Spring
Plastic door latch spring to fit the washing machine models listed More InformationIn stockIn stock£9.25 -
Cooker Selector Switch - ITW 91 - 900106
Genuine replacement part. Suitable for a range of Belling, Stoves and New World Cooker and Ovens. More InformationIn stockIn stock£16.49 -
Cooker Control Knob
Genuine replacement control knob used on the Belling cooker and oven models as shown or as specifically advised More InformationIn stockIn stock£15.49 As low as £13.99
